lehoako
Értékelés: 1023
Hozzászólás Szerző: lehoako »
Shimano írta:
2020.03.08., vas. 10:29
Ezeket még nem láttam a diy piacon,de előbb utóbb biztosan lesz. :D
3×1.5,és 3×2.5mm2 méret.Guszta,és van belőle ösvénynek való tömör verzió is.
Próbálta már valaki esetleg?
inakustik-referenz-ac-2502f-3x25-mm2-halozati-tapkabel-10m-00762512-530566.jpg[attachment=1]inakustik-referenz-ac-2502f-3x25-mm2-halozati-tapkabel-10m-00762512-530566.jpg
Már 1 fokkal jobb a PE, mintha PVC szigetelése lenne...
Pici angol akkor a latinóra után :D
"What is the best insulation material for high fidelity cables?
Most low end (mass consumer) speaker cables are made with Polyvinyl Chloride (PVC) insulation. These are
cables that you typically buy at Best Buy, Walmart, and Radio Shack.
Polyvinyl Chloride (PVC) has a high dielectric constant and actually attacks the copper over time (copper
poisoning). This type of insulation should be avoided for a high fidelity audio system.
Polyethylene (PE) is a step up from PVC. PE has better dielectric properties. Using the same cable design, a
PE insulated cable will sound better than PVC. Many hi-end cables are made from PE or Foamed PE insulation
and they can be priced from a few hundred to thousands of dollars.
Polypropylene (PP) is slightly better than PE in dielectric property and sounds better than PE. However, PP is a
very stiff material, so the cable made from PP insulation has very low flexibility. Only a very few companies
make PP cables for audio applications. These are also very high priced.
Teflon (FEP, PTFE, PFA) is the best insulation in terms of dielectric properties and resulting in the best sound
for audio cables. Cables made with Teflon are expensive, but they are worth the price of admission.
Be careful with some cables that are Teflon insulated, but the conductor is silver plated copper. This type of
cable sounds very edgy due to the different velocity (phase) of the copper and silver material.
http://www.zentaracables.com/Technical.aspx
Uccsó kiemelt sor, mit tesz a véletlen, egybevág a Habiával való tapasztalataimmal...
hodyka
Értékelés: 441
Hozzászólás Szerző: hodyka »
wittao írta:
2020.03.08., vas. 09:53
fülelek írta:
2020.03.08., vas. 09:38
Errare humanum est, sed in erare perseverare in stultum esse :napsut:
Beirtam gugli forditoba, erre ezt irta ki:
Errar es humano, pero para continuar a volver estúpida
Hat nem lettem elorebb ;peace;
Valahogy ez a lényege :D
Tévedni emberi dolog, de ha mindig, akkor buta vagy
Shimano
Értékelés: 2168
Hozzászólás Szerző: Shimano »
diagnet
Értékelés: 605
Hozzászólás Szerző: diagnet »
lehoako írta:
Sapienti sat.
Ab initio nullum - semper nullum.
pali923
Értékelés: 1217
Hozzászólás Szerző: pali923 »
Próbáltad a nyelvet átállítani banturól valami másra? :P :D
Értékelés: 5226
lehoako
Értékelés: 1023
diagnet írta:
2020.03.07., szomb. 12:06
lehoako írta:
2020.03.07., szomb. 07:33
Ezt nem tudom, lehetséges, de szerintem vadonatúj kábellel 200-300 óráig csak bejáratni nem mindenkinek a vágyálma.
Ezt a bejáratást hogyan kell elképzelni? Feszültség alatt átrendeződik a vezető rácsszerkezete? Mi garantálja, hogy 300 óra után megáll a folyamat? Gyártás során elhelyeztek speciális atomokat, amik 300 óra után megtalálják a végleges helyüket és többé nem reagálnak semmiféle környezeti hatásra?
Sapienti sat.
cat7505
Csatlakozott: 2015.06.28., vas. 11:57
Értékelés: 52
Hozzászólás Szerző: cat7505 »
trane írta:
2020.03.07., szomb. 16:43
cables írta:
2020.03.07., szomb. 10:29
Saját vélemény ( mint ugye mindenkié :) ), amelyik kábel járatás nélkül nem hozza az elvárt mértékű javulást, azzal nem érdemes foglalkozni!
nemtom, Rudolf, de nálam járt olyan kábeled, ami helyből nem volt akkora ugrás, azonban lényegesen jobban szólt a bejáratást követően, mint előtte gondolkodik.gif
Lehet tagadni a dolgot, de bejáródás létezik és ez ügyben én a saját fülemnek hiszek inkább
(amely képes érzékelni a kábel helyének vagy helyzetének változtatása okán fellépő időleges anomáliákat is)
mint azoknak akik ódákat zengenek X vagy Y termékről, de halvány segédfogalmuk sincsen mit is jelenthet a zárójeles rész...
diagnet
Értékelés: 605
wittao írta:
2020.03.07., szomb. 12:32
Ja... nem... tévedtem: Albert Einstein mondta.
Tipp: Az Einstein-Schrödinger-Newton vonal még a XX. sz-i nyomtatott média hasábjain és a közbeszédben kifulladt.
A munkásságukból kiragadott idézetek fűre-fára ráaggatása már akkor is kínosan hatott.
A posztmodern kor interneten okosodott népe Steve Jobs, Elon Musk féléket használja hivatkozási alapnak.
Ezekhez a "hightech" termékekhez jobban illenek a frissen felfedezett karakterek.
diagnet
Értékelés: 605
cables
Értékelés: 2316
Hozzászólás Szerző: cables »
lehoako
Értékelés: 1023
cables írta:
2020.03.07., szomb. 06:59
lehoako írta:
2020.03.06., pén. 18:40
Forgalmazótól, teljes áron elhozni vmi cuccost, hát nem tudom... de ha Te tudod... :D :D :D
Gondolom próbára saját rendszerben van mód a forgalmazóknál is. Úgy értem visszaveszik, ha valami nem válik be.
Ezt nem tudom, lehetséges, de szerintem vadonatúj kábellel 200-300 óráig csak bejáratni nem mindenkinek a vágyálma. Ezek után megveheti az illető listaáron. Ehelyett itt a fórumon sztem jobb lehetőségek vannak. :smile53:
cables
Értékelés: 2316
lehoako
Értékelés: 1023
Jozzz írta:
2020.03.06., pén. 10:37
MrCollector írta:
2020.03.06., pén. 10:27
Jozzz írta:
2020.03.05., csüt. 11:59
Kis segítséget/véleményt szeretnék tőletek kérni. Házimoziól átváltottam sztereóra, és a sztereó láncomba keres kábeleket, de nem igazán tudom, hogy milyen kábelek között keressek (ár kategória/típus).
Így néz ki jelenleg:
DAC: ASUS Xonar Essence One
Erősítő: Denon PMA1500ae
Hangfal: Audio Physic Classic 20
A zenét jelenleg számítógépről szolgáltatom Foobar2000 segítségével, későbbiekben lemez lejátszóval is bővülni fog.
Tudom, az erősítőn lehet fejleszteni, mivel a hangfalak többet tudnak, de az majd egy későbbi story lesz.
A DAC-Erősítő közé keresek RCA kábelt, valamint az erősítő és a hangfal közé. Tápkábelnek egy AQ NRG3 van jelenleg, és azt nem bántom most.
Milyen kábelek működhetnek jól ezekkel a cuccokkal?
Köszönöm szépen előre is a segítséget :smile53:
Józsi
Szerintem azt kellene eldöntened mennyi az összeg amit rá akarsz/ tudsz szánni. Addig felesleges bármit is ajánlgatni.
Értékhatárt nem lőttem be, ésszerű keretek között szeretnék maradni. De természetesen, nem akarok sok 100e Ft-ot költeni rá. Gondolom úgy max.100-150k-ba szépen be lehet férni használtan...
Így van, nyomulj használtban, ahogy írtam, be vannak járatva és kb féláron megcsíphetők, pláne, ha már többedik tulaj cseréli le őket. Forgalmazótól, teljes áron elhozni vmi cuccost, hát nem tudom... de ha Te tudod... :D :D :D
zenta
Csatlakozott: 2018.10.04., csüt. 23:22
Értékelés: 108
Hozzászólás Szerző: zenta »
Józsi
Szerintem érdemes lenne meghallgatnod a Hidiamond kábeleket. Több szintjük van, a forgalmazónál letét ellenében kipróbálhatók. Nekem bejöttek és az ár-érték arányuk is jó.
Rega P6/Goldring 1042, Heed Obelisk DT, cirrus7 ROCK szerver, sMS-200 NEO, Border Patrol SE DAC, diy ACP+, diy Pass ACA dual mono, diy szélessávú/Markaudio
MrCollector
Értékelés: 482
Józsi
Hát akkor a helyedben filléres megoldásokkal nem húznám az időt.
Ha kérdésed van: 20/3383456
Jozzz
Csatlakozott: 2016.07.18., hétf. 18:02
Értékelés: 9
Hozzászólás Szerző: Jozzz »
Józsi
Dynaudio Contour 20 - Audio Hungary Qualiton A50i - Auralic Aries G1 - M2TECH Young DSD +lineáris táp - Niagara 1200 - Pillartech Audio rack
MrCollector
Értékelés: 482
Józsi
lehoako
Értékelés: 1023
Jozzz írta:
2020.03.06., pén. 08:24
lehoako írta:
2020.03.06., pén. 08:02
Józsi
Szerintem próbálj ki először egy alapszintű rezet, pl Klotz MC 5000-kategória, vagy valamilyen DIY drótot, (sztereó métere 906 Ft)
https://elimex.hu/termekek/12438/klotz_ ... ?catid=598
aztán szokd meg a hangját, ez kb 2 hónap. Valószínűleg tetszeni fog.
Aztán próbálj szerezni egy alapszintű ezüstöt, itt a fórumon is árulnak ilyet, kösd be és magint hallgasd kb 1-2 hónapig, fontos, hogy jól be legyen jártatva, mert egyébként se a réz, se az ezüst nem lesz az igazi.
Ezek után már kb tudni fogod, mire vágysz, jöhet az ezüstözött réz (Habia bármilyen formában), aztán már csak próbálgass, kérj kölcsön és hallgasd.
Az ASUS nagyon jó, részletező hangú DAC, rézzel se lesz semmi bajod vele. :smile32:
SZVSZ. :smile53:
Szia,
Nagyon szépen köszönöm a tanácsot :smile53: Kissé más kábelekkel, de ennek most pont eleget teszek :) RCA-nak egy QED profile kábelt használok, hangfal kábelnek pedig egy Chord Company Clearway. Ezüstözött rézkábelhez valami típus ajánlás?
Józsi
HABIA DIY, vagy, ha találsz olcsón, akkor régi Nordostok, érdemes végigjárni a létrácskát, Solar Wind (ilyet sztem már sehol nem fogsz találni), Blue Heaven, Red Dawn (régiek, szalag-felépítésűek). Feljebb már csak akkor költs, ha biztos jó Neked ez az irány. Régiek kellenek, olcsóbbak és jól bejáratottak. Most láttam egy SPM reference-t az adivétiben, rámennék én is, dehát sajna az már nagyon-nagyon drága (nekem). Ez az én tapasztalatom, én ezt vizsgáltam végig, ezt tudom ajánlani. :smile32:
Indulj az USB-kábeltől. :smile32:
Jozzz
Értékelés: 9
Józsi
SZVSZ. :smile53:
Szia,
Józsi
lehoako
Értékelés: 1023
Józsi
SZVSZ. :smile53:
De ha kész HM rendszered volt, abban is biztosan voltak IC kábelek. :D
Sztem egy jó USB-kábel kellene a rendszeredbe, a nullforintos, ingyenes, pléhből húzott kínai USB-kábel nem igazán való a hifihez. Sztem kérj kölcsön egy alapszintű rezet, már tudni fogod, honnan hová. Írnám, h Schmidt Feri, ha jól írom, ami nagyon jól szól, jelenleg is parkol nálam 1 kábele, amit lassan vissza kéne küldenem asebestyénnek... (Ezúton is bocsánat Tőle... :smile53: :smile53: :smile53: )
lehoako
Értékelés: 1023
2020.03.05., csüt. 08:24
lehoako írta:
2020.03.05., csüt. 07:38
2020.03.04., szer. 23:07
Miért? Ez most kifejezetten kellemes kis csevegés ahhoz képest, hogy milyen csetepaték szoktak itt zajlani :D
Megvan mindenkinek a maga véleménye, ez rendben is van, amíg kultúráltan mondja el. Lehet vele egyetérteni vagy nem egyetérteni, illetve vitatni szintén kultúráltan, érvekkel.
Ezt persze nem azért írom, hogy beinduljon a veszekedés, mert akkor a takarítás is beindul :ohnoohnoohno:
Csak így tovább!
Aszpi, de jó, h beírtál! Mi van az új ezüstkábellel? Bejáratódott, maradt vagy visszavitted?
Bejáratódott, maradt ☺︎
Placebó vagy sem, nekem jobban tetszik, mint a többi, amit ezen a poszton (AES/EBU) itthon hallottam.
(amint azt már többször leírtam, nincs semmi problémám a placebóval, ha az, mert ha működik a dolog, akkor nem mindegy, hogy placebo vagy egyéb?)
Azért azt gyorsan megjegyzem, hogy nem minden, ami ezüst, vált be ennyire. Van egy diy ezüst RCA digit összekötőm, többször győzködtem magam, hogy jó, de sem elsőre, sem később valójában nem sikerült megbarátkoznom vele, így most elrakva pihen, amolyan “szügségtartalékként”. “Cingár“ volt a rendszerem hangja, amikor azt használtam. Szándékosan nem írom, hogy a kábel “hangja”, mert még mindig meggyőződésem, hogy hangja egy rendszernek van egy adott akusztikai környezetben, aminek minden eleme többé-kevésbé hozzájárul a végeredményhez, és a digitális kábelek a “kevésbé” területen mozognak. Ennek ellenére az én “rendszeremben” tud hallható különbséget okozni egy másmilyen digitális kábel. De nem “ég és föld”, ahogyan itt megszokott kifejezni minden apróságot. Az aktív elemeknek és a hangsugárzóknak azért véleményem szerint még mindig sokkal nagyobb a szerepük az összképben, mint a kábeleknek. De az utóbbiak sem elhanyagolhatóak. Ha placebó, akkor sem :D
Köszi, C9H8O4!
Ugyanúgy, ahogy a rézben, biztosan az ezüstben is van hangbani skála, meg nyilván adott rendszerhez passzoló/nem passzoló szinergia-faktor.
Nyilván felesleges vitát nyitni arról, hogyha x ezerért megfőztél egy nagy bogrács marhagulyást, akkor kell-e bele még fél kanál só vagy nem, meg, hogy miért nem tettél bele eleve sósabb répát, ha úgy szereted, :D , mert akkor nem kéne a végén ízesíteni, de ezzel együtt aláírom, hogy nyilván a végeredmény a fontos, ami azért, valljuk be, az összetevőkből alakul ki.
Akkor, ha jól értem, "összeállt" a rendszer hangja, eddig így a legjobb. :smile32:
hodyka
Értékelés: 441
migabi24 írta:
2020.03.05., csüt. 14:40
hodyka írta:
2020.03.05., csüt. 13:35
Ez kimard és ez a lényeg szerintem
Csak és csak tömör egyeres rézdrót legyen mindenhol
Ez 1 jó nagy hülyeség.
hodyka
Értékelés: 441
DirtyMashine írta:
2020.03.05., csüt. 14:54
hodyka írta:
2020.03.05., csüt. 13:33
DirtyMashine írta:
2020.03.05., csüt. 13:03
én tápkábelről és digitális jelátviteli kábelről beszéltem és nem analóg kábelekről. De jó sok poszt született előzményolvasás nélkül
Igen is van különbség, nem is kicsi, aki nem hiszi járjon utána :D
Aki nem halja, azt irígylem, nem kell drótokkal kinlódjon :fekverohog:
Tápkábelnek is vannak nagyon jó és olcsó drótok
Digitálishoz: USB saját drót és nagyon meg hallatszik a hangon, COAX SPDIF, szintén saját készítés
Több helyen is bizonyítottak
usb? tehát usb-n megy az erősítőbe a digit jel és az erősítő a dac? Mert ha igen fizikai képtelenség hogy más legyen a hangja.
Van olyan is a családban, a Fiamnak, Lumin M1 és nagyon jó
De nekem van egy UDB DAC-om ami egy D osztályú erősítőt hajt analógba
"fizikai képtelenség hogy más legyen a hangja."
Szerinted, érdekes mások szerint meg igen
Ha többet akarsz tudni keress meg 06 70 382 75 91 a számom
MrCollector
Értékelés: 482
DirtyMashine írta:
2020.03.05., csüt. 16:24
MrCollector írta:
2020.03.05., csüt. 16:15
DirtyMashine írta:
2020.03.05., csüt. 16:10
Nem az a gondom hogy nem lehet kapni hanem hogy kínában egy rakat kamut gyártanak. Inkább költenék 100ft helyett 500ft-ot vagy pár ezret olyan ferritre ami biztos hogy az aminek hirdetik. Erre irányult a kérdés, hogy mely hol és milyet érdemes vásárolni.
Akkor vegyél Viablue-t! Kábelvastagságtól függően 3500-5000 Ft/db.
Ezért mondom, hogy nem olvastok csak írok. Ez volt az első postom és erre jött a sok tápkábeles marhaság:
"Milyen ferrit terméket tudnátok ajánlani? Ezt ismeri esetleg valaki? https://audiofeelings.hu/viablue-ferrit ... 18-meretig
Esetleg olcsóbb de megbízható márkát? Köszi. "
Akkor jó lenne, ha a sajátodat is tudnád értelmezni: "pár ezret olyan ferritre". Olcsó és megbízható? :D
