Eladó egy földelő kábel lemezjátszóhoz, ebayen vettem kettőt, de egy is elég volt, nem használtam....
Az ára 2500 ft
0.6m Ground / Earth wire Fork Terminal at both ends Turntable Hi-Fi Audiophile
This for ONE nbspares Turntable Ground / Earth wire, our cable is made from high-quality 18AWG guage copper cable, and features double-crimp fork terminals at both ends, meaning that both the outer insulator, and inner conductor are crimped, producing a far stronger and more durable connection than a single-crimp or solder terminal where only the conductor is secured, which can easily break over time due to the strain from flexing.
The terminals on our cable are then covered in an adhesive lined heatshrink, creating a sealed joint to prevent moisture ingression in to the crimped joint.
This cable is 0.6 Metres / 60cm / 23 Inches long, with a Fork terminal on each end. This is usually the ideal length for connecting a turntable situated directly next to a mixer.
0,6 méteres földelő kábel
Hozzászólás Szerző: waters »
- 2020-01-25 20.21.35.jpg (5.8 MiB) Megtekintve 320 alkalommal
- ↳ Zsolt Audio
