Harbeth hangsugárzók
AVX
Értékelés: 3308
Hozzászólás Szerző: AVX »
M40 internal view during assembly
AVX
Értékelés: 3308
Monitor 30
AVX
Értékelés: 3308
Electrical characteristics - easy load
AVX
Értékelés: 3308
P3ESR's RADIAL2 bass/midrange driver
AVX
Értékelés: 3308
Super HL5 váltó
AVX
Értékelés: 3308
Monitor 30 domestic
Ez pedig a másik BBC monotor utóda:
Initially developed as a drop-in replacement /upgrade for the BBC LS5/9 studio monitor, the convenient proportions and well rounded sound soon led the Monitor 30 into the domestic market where it's acclaimed as the perfect 'all-rounder'.
Compared with its big brother Monitor 40.1, the cabinet is only about half the height and a quarter the volume; the Monitor 30 to sonically and visually disappears into a domestic listening room when mounted on a matching stands. Engineered around Harbeth's RADIAL™ technology, the Monitor 30 achieves effortless clarity throughout the midrange, with extended bass and at higher levels than the Monitor 20 - but with the same family balance as the flagship Monitor 40.1.
AVX
Értékelés: 3308
harbeth Monitor 20
Erről is azt írják,hogy az LS3/5 utóda:
The Monitor 20 is a professional loudspeaker designed to replace the BBC's LS3/5A. Extensively used in professional near-field monitoring applications, the Monitor 20 is exactly the right balance of sound and size that make it perfect for monitoring.
AVX
Értékelés: 3308
harbeth P3ESR
Találtam egy másik képet is,de ez nem pont olyan,mint az előző.
AVX
Értékelés: 3308
harbeth P3ESR
AVX
Értékelés: 3308
harbeth P3ESR
AVX
Értékelés: 3308
harbeth P3ESR
Nem tudom ennek mennyi köze van az eredeti LS3/5-höz?
The all-new RADIAL2™ coned Harbeth P3ESR is the ultimate mini monitor, the latest in a lineage that stretches back twenty years to the original Harbeth P3 and even further to the BBC's pioneering LS3/5A. A generation of home users and studio professionals has relied on these Harbeth minis to fill even the smallest room with a full, warm, natural sound. The P3ESR is the culmination of the designer's four-years research into upgrading the Harbeth mini. From the new removable back panel for improved cabinet damping to the radically new bass unit yielding a wide smooth frequency response, every detail of these astonishing loudspeakers has been thoroughly honed and optimised. The objective has always been to create the genuine Harbeth sound in miniature: the P3ESR (R for RADIAL™) is that much closer to reality.
AVX
Értékelés: 3308
Valószínű arra gondol, hogy nálam is egy klón zenélt sokáig.
Örülök,hogy elég sokan hallgatnak ilyen kis dobozokat.
pj-
Csatlakozott: 2009.02.22., vas. 07:56
Értékelés: 725
Hozzászólás Szerző: pj- »
Kis hazánkban nem tudok eredeti LS3-at, mondom, akarom mondani ... írom EREDETIT!!!Különféle utánépítéssel igen, de nem EREDETIT.
Bár azt nem tudom, hogy az LS3 micsoda, de gondolom LS3/5a-ra gondoltál.
Szabadna megtudnom, hogy mit tekinthetünk EREDETI LS3/5a-nak?
ROGERS LS3/5a akartam írni, mivel az volt az eredeti konstrukció.
A Harbeth, Spendor, Jungson mind-mind clone hangfal
chord
Értékelés: 2223
Hozzászólás Szerző: chord »
Bár azt nem tudom, hogy az LS3 micsoda, de gondolom LS3/5a-ra gondoltál. Szabadna megtudnom, hogy mit tekinthetünk EREDETI LS3/5a-nak?
Valószínű arra gondol, hogy nálam is egy klón zenélt sokáig. 11 Ohmos eredeti (dobozból kiszerelt) hangszórókészlet, eredeti keresztváltó, mm-re pontos doboz ugyanabból az anyagból, szivacs, bitumen, stb. ugyanúgy, semmin nem módosítva.
A gyári 11 Ohmostól nem tudtuk megkülönböztetni.
A 15 Ohmostól annál inkább .
blog: Komolyzenei ajánló
chord
Értékelés: 2223
Totálisan ellent kell hogy mondjak -muszáj
Ha már ilyen szépen belemerülünk ebben a témában, fordítsuk le a dolgot, van egy viszonylag jó hangú és megfizethető doboz, amit sokan felismerve, kiemelik a tömeg termékek közül, s mindez idővel kultikussá válik.
Ha már kultusz, tessék nekem megmondani az eredeti milyen kábelezéssel, s milyen gyártású rézzel készült (orosz, chilei, stb?). Milyen a vasmag alapanyaga?
Ugyanis -örült hifisták szerint (mint Mi)- a régi vasmagog mások (jobbak?) mint a mostaniak.
S ha már vasmag, ugye sokan tanulták a hiszterézis görbét és annak hatásait?
S ha más vasmag, akkor azok egymásra hatása a keresztváltóban és a meglévő mágneses térrel?
Az eredeti konstrukcióban a gyárthatóság, eladhatóság és az olcsóság (egy bizonyos szinten) volt a szempont.
Szóval -én úgy érzem- nagyon túl van ez misztifikálva.
Üdv:PJ
Azzal kezdtük, hogy jó lenne egy korrekt összehallgatás a Jungson/eredeti között.
Az Ethoszé is érdekes lenne, mert a váltón kívül minden eredetinek mondható, a váltó pedig egy különös gonddal épített rendszer, pazar alkatrészekkel, nyilván a jobb hangot célozva.
Utána talán okosabbak lennénk.
endeavourSE
Csatlakozott: 2010.03.12., pén. 19:06
Hozzászólás Szerző: endeavourSE »
pj-
Értékelés: 725
Totálisan ellent kell mondanom nektek.Ez a "misztifikálás" úgy tűnik, nem túlzó. Van egy csoportja a zenehallgatóknak, akik a lent említett "misztikus" paramétert kihallják az eredeti dobozból, s más hangdobozban rendkívül ritka esetben találják meg. A klónokban sem.
Sokan itthoni mércével túlzó HighEnd amplifikációval hallgatják - talán ez fontos.
Meg az, hogy olyan hangsugárzókkal finnyáskodnak, hogy aki nem hallotta igazi jó láncban az LS3/5a -t, annak egyszerűen nevetséges a helyzet, tekintettel pl. az elképesztő árkülönbségre.
A nemzetközi levelezőlistán hónapokig lehetett olvasni különböző tuningokról.
A keresztváltó kialakítása sok ember műszaki érzékét piszkálja. Főleg azokét, akik hiszik a jobb alkatrész - jobb hang relációt. Rengeteg próbálkozás született pl. a kondenzátorok cseréjével; egészen drága, spec. audiofil kondik kerültek be. (aztán meg ki)
A vasmagos trafók helyett elképesztő hard-wiring váltókonstrukciók, szintén nem kímélve a pénztárcát. Nem volt áttörés. Néhány esetben született egy tényleg jó, de 'varázslat' nélküli hang.
Rengeteg a széthajtott/kissé leégetett/stb.. mélyközép van sok dobozban; valóban a Monacor hangszóróján még a lyukak is passzolnának. Sokan próbálták meg - kaptak egy "főleg háttérzene szolgáltatót" - csak pont a lényeg kimaradt.
Tagok jöttek-mentek EasyJet jegyekkel, még Malaysiába is, hallgatták, okoskodtak, összegeztek.
Talán egyetlen változtatás jött be. Ez is egy visszalépés a kezdeti modellekhez: a dobozfal további vékonyítása. Valóban, a "thin wall cabinet" lényegesen jobban szól - én is tanúsítom.
Egyetlen elismert tuningcég tudott érdemben javítani a keresztváltó módosításával: a Cicable, igazi ultra-horror áron.
Szóval a többség marad az eredeti konstrukciónál, eredeti váltónál és a varázslatnál, szánakozó mosollyal a vergődéseken.
Ebben van sok sznobéria, hit, nosztalgia - viszont szerintem sok igazság is.
Az Ethosz dobozban nem eredeti váltó van. Hangszórók eredetiek, 15 Ohm -os készlet, a doboz egy príma, 'thin wall' kabinet kópia. Nem hallgattam saját láncban.
A "másik csoport" akik szerint az LS3/5a egy nagyon jó kis doboz, szép közepekkel - de semmi elképesztő - valószínűleg nem fogja a fentieket elhinni/elfogadni.
Üdv
Chrd
Üdv:PJ
Tomi
Csatlakozott: 2009.01.21., szer. 06:18
Értékelés: 90
Hozzászólás Szerző: Tomi »
Üdv
Chrd
Valamilyen alrendszer cseréje nem feltétlenül hoz változást az egész rendszerben, ha a jobb hangzás akadály nem abban rejlik. Az LS3/5 egy kiforrt rendszer a 70es évek legjobb minőségű hangszóróival, az akkor technikai színvonalon. A váltóinak az alkatrészeiben hiába cserélget bárki (ennél a típusnál elég kicsi a mozgástér), ott minőségi ugrást nem nagyon lehet elérni, ellenben a hangszórók cseréje sokkal komolyabb különbséget jelenthet (nyilván ez magában hordozhatja a doboz méretének változását is). A mai Seas, Scanspeak hangszóró sokkal precízebbek, ez persze bánthatja egyes emberek fülét, akik a régi hangládák tipikus hangjához edzették a fülüket. Mindez csak megszokás és hozzáállás kérdése. Ettől függetlenül minden audio mérföldkő előtt fejet kell hajtani, hiszen ezek viszik tovább az ipart és okoznak egyre több örömöt az embernek.
potatomelon.wordpress.com
chord
Értékelés: 2223
Üdv
Chrd
Tomi
Értékelés: 90
Itt is az a lényeg, hogy ésszel kell mindent csinálni. Bélánál lesz egyébként majd lesz valamikor egy összehasonlító meghallgatás, csak még nem tudom mikor lesz érkezésem. Egyébként szétbombáztam a kis Harbeth-et és ledokumentáltam a paramétereket. Azt hiszem le fogom másolni, ha találok mélyközepet is hozzá, ami baromi ritka. Ha nem, akkor Monacor-ból oldom meg, de akkor az már más lesz. Képet majd töltök fel.
Szerintem ez is,mint minden túl van misztifikálva.
Nekem van egy másik dobozom,amit az Ethosz épített eredeti doksi alapján,eredeti Rogershez használt hangszórókkal és váltóval.
Nagyon minimális különbséget éreztem a Jungson és a Rogers között.
Én nem igazán hiszek abban,hogy egy gyári minden esetben jobb,mint amit utólag építettek.Nem hiába létesültek a világ minden pontján profi tuningoló cégek.A CD játszótól kezdve a hangdobozokig,mindent tuningolnak.
Nekem is van olyan dobozom,ami megvan eredeti és tuningolt változatban is.A tuningolt jobban tetszik.Ilyen dobozom a Swans M1 és a Dyno 52-es.
Ez így van. Sokkal inkább a nosztalgiáról szól a dolog. Ettől függetlenül nagyon okos kis konstrukció, kis helyen elfér, szép a hangja, relatíve pontosan szól, igazi háttérzene szolgáltató. Ezért is gondoltam lemásolni. Ma már vannak hangszórók, amik részletgazdagabban szólnak, én is gondolkodom egy ilyenben pl. KEF T27 helyett Seas 27TFF magasat, a közép KEF SP228 helyett pedig Monacor SPH-135AD-at tennék, csak a váltót kellene átvariálni.
AVX
Értékelés: 3308
Tomi
Értékelés: 90
mishow
Értékelés: 2539
Hozzászólás Szerző: mishow »
Azért párunkat érdekelne egy korrekt Jungson LS3/5a vs. Harbeth (vagy Rogers) LS3/5a összehallgatás eredménye.....Ami még fontos: az eredeti LS3/5a hiába jól hajtható, olcsó tranzisztorossal csapnivalóan rosszul szól.
Csatlakoznék a kíváncsiak táborához! :lol!:
A Jungson klón is produkált érdekes dolgokat.
Meghallgattuk néhány párosításban: általában nem volt válogatós, sőt néha olyan erősítőkkel is jól szólt, amivel nem vártuk volna, máskor pedig egy elvben jó felállásban kapitulált.
Az olcsó kis Jungson 66C erősítővel pl jól elvolt, a kisebb Crekekkel (EVO, 5350) is - de a drága (és "bika") Creek Destiny-vel utálták egymást. A Vincent, vagy a Unico hibridekkel is nagyon zenei volt, a Yaquin hibriddel pedig katasztrófa.... :kiraly: :kiraly:
chord
Értékelés: 2223
Az LS3/5a levelezőlistán enyhén szólva hűvös volt a fogadtatás. (pedig egy erős kínai/hong-kongi frakció is van) Ott persze a Spendor S3/5R -t sem vették be a klubba. Arról a megfoghatatlan/megmérhetetlen paraméterről esett a legtöbb szó, amely borzongtatóan hitelessé tesz egy zongorahangot, vagy egy különösen bonyolult szopránáriát - amit jómagam is pár évig csodálhattam.
Bonyolítja a dolgot, hogy ez nem mindenkinek annyira fontos, mint főleg a klasszikus zene hallgatóinak - a listán ez a legerősebb csapat.
mishow
Értékelés: 2539
Ma meghallgattam a Harbeth LS3/5A-t a frissen beszerzett Unison Research S2K csöves erősítővel.
Nálam a Jungson féle LS3/5 klón szólt Unico Secondo hibriddel, Evidence Siren II kábelekkel biwire bekötve, bő három héten át.
Az is nagyon jól muzsikolt, csak épp akkor nem (sem) volt egyben a pénzem a Secondora.
Ezt a Harbeth dobozt sajnos benéztem, mert ritkábban fórumozok mostanában. Ha időben észreveszem, tuti h most nálam lenne!
Csak az vigasztal, hogy látom, te magad is élvezed és értékeled, úgyhogy sok örömöt hozzá! :lol!:
