Cambridge Audio termékek
Az alábbi szöveg a 640C v2 leírásában található, és a v2-ben levő fejlesztéseket taglalja. Ha esetleg valaki, aki jobban tud angolul, mint én, fel tudna homályosítani, hogy miről is van szó (azon kívül, hogy már 2 DAC és toroid trafó van benne), megköszönném.
For the Version 2 models, we have significantly upgraded and improved theDigital to Analog stages as well as the anti-aliasing filters for even better
sound quality.
The 640C V2.0 now employs a pair of WM8740 24 bit/192 kHz capable
Digital to Analog converter from Wolfson Microelectronics implemented in a
dual differential configuration. As each channel has its own DAC to process
information, completely separate analog filter circuitry can be implemented.
Moreover, because of the separation of left and right audio converters, the
640C V2.0 embraces a symmetrical layout. This ensures that both left and
right channel circuitry operate identically, ensuring the 640C V2.0 delivers
fantastic sound-staging and stereo imaging properties. The dual differential
configuration also offers better signal-to-noise ratios and exceptionally low
distortion characteristics in part from the use of a new version of our
proprietary Double Virtual Earth Balanced filters.
The 640C V2.0 features a new Four Pole Dual Differential Double Virtual
Earth Balanced topology. This means the DAC for each channel features two
fully balanced outputs each of which are then summed in a 3rd order virtual
earth balanced filter stage, then a further 1st order balanced filter stage
sums the balanced outputs of the earlier filter stages. This double balanced
configuration largely rejects noise and distortion products present in the
DACs and filters and provides an unprecedented level of performance. As
with the 540C V2.0, a new toroidal transformer is now fitted giving lower
noise and less waveform distortion for quieter PSU operation.
Tsc: jobban is szólt dupla DAC-kal?
Tudom is én? Nincs ilyenem, csak v1 volt (azért azt szerettem).
De a magazinok szerint jobb lett. Többe meg asszem nem kerül, tehát elvileg ha javult valamit, az csupa ajándék.
Nekem az a véleményem hogy ez a multiroom marhaság csak egy divatos valami, lassan mindenki (pl. egyik fő ellenlábasuk, a H/K) is belerakja minden cuccába, aztán kíváncsi vagyok ki használja ki a gyakorlatban. A másik ilyen okosság most az iPod dokkolhatóság, ez a trend, ez van.
Azért a HTD bemenet ilyen szinten való beintegrálása egy erősítőbe ez elég barátságos dolog, és sokan pont erre vártak már mióta, hogy legyen egy elviselhető árú HTD-s integrált erősítő, mert nem mindenki tért még át - vagy fog áttérni - a fullsztereóra.
- Torzonborz
- Csatlakozott: 2003.10.13., hétf. 11:04
- Értékelés: 0
Érdekes irányba vonul a CA.
Kb. hasolnót szeretnének kiváltani az emberekből, mint amit Torzonborz-ból.
Nekem ez nem túl szimpatikus. SZVSZ!
Ezt nem igazán értem... Mit is váltott ki belőlem? Mindössze annyit, hogy szeretném meghallgatni, ha elérhető lesz; és felveszem a jelöltek listájára...
A rendelkezésre álló információk alapján szimpatikusnak tűnik a specifikációja, amiből nyilván nem lehet messzemenő következtetéseket levonni. Nem is tettem. Ennyi. Ebből semmi nem következik, és még az is lehet, hogy soha nem fogok se 840A-t, se más CA-készüléket venni...
Bocs, de mi is az a dimmelhető kijelző ?
A fényerejét tudod szabályozni.
Nekem is hasonló a véleményem, mint Mathias-nak.
- kaltenpeti
- Csatlakozott: 2005.11.23., szer. 22:58
- Értékelés: 22
Hát én kezedem úgy érezni, hogy a CA nagyon elmegy abba az irányba, mint anno a HM erősítők. Ezek a V2 kiadások, ha jól látom, csak abban különböznekaz elődöktől, hogy tudnak pár fölösleges funkciót(pl. incognito, vagy mi). Meg asszem a THD is rosszabb lett(nem mintha nagy jelentőséget tulajdonítanák neki) Inkább adnák olcsóbban, vagy mást javitanának. SZVSZ.Ez a kijelző is ilyesmi szerintem.
A 640-es cd v2 kiadása nem csak felesleges funkciókkal több:
- dupla dac
- toroid trafó a sima helyett
- dimmelhető kijelző
- Torzonborz
- Értékelés: 0
Hmm... lehet, hogy ez az az erősítő, amire már hosszú ideje várok? A szolgáltatásai nagyon rendben vannak, a műszaki adatok is, és ha még jól is szól, akkor lehet, hogy benevezek egy ilyenre...
Tényleg nagyon ígéretes ez a rengeteg szolgáltatás. Kiváncsi vagyok én is, hogy milyen a hangja. Ha emlékeim nem csalnak a CD player (840) úgy 200e körül lesz majd.
hát elég jó cuccnak tűnik
vajon mennyiért fogják osztogatni?
AVHIFI Online Store -on 1375$
/CD is és az erősítő is/
Erősítő: Harman/Kardon HK 970 Limited | CD: Harman/Kardon HD 970 | Tuner: Harman/Kardon TU 950 | Hangfal: Dali Ikon 6 | Interconnect: Arzachel + VdH D 102 MK III | Hangfalkábel: Kimber 8 TC
Marantz SR6004 + Heed Canopus, Dactilus3, Onkyo DX7222 cd, Klipsch RP-8000F, Klipsch RC35, Klipsch RB25
Végigolvasva a felhaszn. kézikönyvet, egyre jobban tetszik a 840A.
- Bármelyik bemenetét be lehet konfigurálni, hogy HTD bemenet legyen, akár egyszerre többet is!
- Bemenetek átnevezhetők
- Bemenetekhez külön hangerő korrekció rendelhető
- Beállítható, mely bemenetekre dugott cuccokat kapcsolja ki meg be, mikor bekapcsolod
Integrált erősítőben még nem láttam olyat ami ennyire felhasználóbarát lett volna.
Csak szóljon is jól, meg adják baráti áron.
Szóval akkor a 840C is használható DAC-ként, ahogy elnézem.
XLR kimenet.
Szerintem ez is jó lesz!
Új erősítő a CA-tól. Azur 840
Érdekesen oldották meg a kijelzőt, de nekem tetszik!
Full 840C hátlap
A felhasználói kézikönyvből kiindulva azt gyanítom jön a 840C is.
A leírásban ugyanis az XLR csatlakozást egy 840C -vel mutatja be.
Ez nagyon profinak és innovatívnak tűnik. HTD bemenete is van, dupla toroid az elő-végfoknak, ellenálláslétrás hangerőszabályzás, normális hangfalkábel szorítók, stb.
A hangja persze ki tudja milyen - majd elválik - , de tényleg remek készüléknek nézünk elébe.
CA DVDjátékosokról ki mit tud?van valakinek tapasztalata?
DVD79, esetleg DVD89 érdekelne, beszerzési lehetőséggel együtt.
(Denon 1920at néztem ki, kép az elsődleges, dvi/hdmi legyen rajta, divx nem lényeg, audio cd hang pozitívum ha jó, de megintcsak nem ez a fő szempont)
A DVD-89 felkerült a Netdepo árlistájára, és levették a DVD-79-et. Viszont a DVD-89 jóval többet tud (tudom, hogy ez téged hidegen hagy, de ez már tudja a DivX Pro-t, és az XviD kompatibilitás a hivatalos formátumok között szerepel), ez a készülék már rendelkezik nagy felbontású kimenettel: mind a DVi, mind a HDMi megtalálható rajta, illetve lényeges olcsóbb mint az elődje; ez "csak" 61.900.-Ft-ba kerül!
Én is úgy érzem, hogy ez lesz az én játékosom is, ha sikerül hozzájutnom belőle egy feketéhez ( a hivatalos honlapon szerepel a leírásban)
A DVD 79 a Hifibarlangban vehető meg 70 000 Ft-os áron.
thx, ezt én is megtaláltam.
viszont nem sok tapasztalat van vele... megrendeltem a denont mer türelmetlen vagyok
házimozi:
projector: Samsung SP-A600 vászon: Bydium 96" oldalfeszített erősítő: harman/kardon AVR360 center: B&W LCR-600 S3 (van den Hul CS-122) front: B&W 603 S2 (van den Hul CS-122) surround: Focal Sib-XL sub: B&W ASW-600 (Neotech KHS-441SM)
Minden állat egyenlő, de vannak egyenlőbbek
Négy láb jó, két láb rossz
Helló fórumtársaim!
Nem tudom, hogy észre-e vettétek, de végre hozzánk is megérkeztek a a V2 modellek : link
640C V2 HiFi CD Lejátszó 78 900,- Ft / 640C HiFi CD Lejátszó 71 900,- Ft
640A V2 HiFi Erősítő 78 900,- Ft / 640A HiFi Erősítő 71 900,- Ft
540C V2 HiFi CD Lejátszó 64 900,- Ft / 540C HiFi CD Lejátszó 58 900,- Ft
540A V2 HiFi Erősítő 64 900,- Ft / 540A HiFi Erősítő 58 900,- Ft
Ha valahol találkoznátok olcsóbbal, akkor kérnék egy linket
Ezek nagyon jó árak!
házimozi:
Helló fórumtársaim!
És ezek tudnak valami hasznossal többet?
Helló fórumtársaim!
- kaltenpeti
- Értékelés: 22
- kaltenpeti
- Értékelés: 22
Helló fórumtársaim!
