blackfriar
- Lefelé a lejtőn
- Csatlakozott: 2023.03.23., csüt. 18:28
- Értékelés: 50
És persze ne feledjük, ez az egész hókuszpók a hifi nagyrészére is igaz, akármennyire is fáj.
Hogy miért igaz ez ? Mert ez a faj erre képes.
It is extremely likely to be LLM-assisted or heavily polished by one (my estimated probability: ~65-75%).
Linguistic Features That Scream "LLM"
The text has almost every modern telltale of LLM-generated marketing prose (especially 2024–2026 models trained on vast amounts of audiophile copy):
Buzzword density and technobabble: "Microscopic energy compensation", "time-domain correction", "analog time linearity", "natural time balance", "small charge and discharge delays introduced by wire, connector, and medium interactions". These are plausible-sounding but scientifically vague phrases that LLMs love to synthesize from training data on cables, purifiers, and "tweaks".
The classic audiophile "invisible magic" trope:
"Laboratory measurements show no change in frequency response or distortion; however, every sound returns to its natural place". This exact formula ("measures the same but sounds transformed") has existed for decades, but LLMs reproduce it with perfect fluency and zero hedging slips.
Repetitive "restores the natural" motif: "restores the natural time balance", "restoration of analog time linearity", "restores the natural rhythm", "returns to its natural place". LLMs often latch onto one emotionally resonant word/phrase and echo it for cohesion.
Polished, error-free structure: Flawless rhythm, balanced sentences, em-dashes used elegantly, quotation marks around "improve" for rhetorical effect. Hungarian designer Zoltán Bay is a real engineer/pianist with 30+ years experience, but English is clearly not his first language—yet this text has native-level sophistication and zero awkward phrasing.
Persuasive framing: It carefully avoids claiming "improvement" (which invites skepticism) and instead uses "restores" / "eliminates" / "returns"—a classic LLM-optimized marketing trick to sound humble and scientific.
Idézet a Grok 4.20 Beta AI használat elemzéséből:tunerman írta: ↑2026.02.24., kedd 08:05Az FB-n már forró téma, legyen itt is az.![]()
https://www.monoandstereo.com/bayz-audi ... dshKoaQZGw
Szép ez...tunerman írta: ↑2026.02.24., kedd 08:05Az FB-n már forró téma, legyen itt is az.![]()
Erősítő: AN OTO PHONO
- tunerman
- Értékelés: 3420
Azért valljuk be, hihetetlenül ronda...
Ránézésre ezért ember pénzt nem ad, pedig q. jó.
A Black Line...
De jó! Gatulálok!K P írta: ↑2026.02.19., csüt. 18:54Igen 35 + évesek lehetnek. Kb a 90- es évek közepén vettem a sajátjaimat Attilától, ezek voltak az első normálisabb drótjaim. Mai napig megvannak. A Black Line- okat kicsit később, azokon Dietz dugók vannak…
vagy az öreg (barna) a jobb és el kell kezdeni mesterségesen öregíteniMOT64 írta: ↑2026.02.19., csüt. 14:27Aztán én is abbahagyom a komolytalankodást, csak még egy gondolat a banánokról: Az a baj velük, hogy hetente meg kell enned 4 x 3 méter banánt, mert bebarnul. Utána meg kezdheted újra bejáratni a rendszert.revox írta: ↑2026.02.18., szer. 14:21most én lőjem le a poént, aki kiállok mások véleményszabadsága mellett? de a poén megszületett fejemben: ha leveszed a héját, esetleg pamutba tekered, lehet jobb lesz
(bocsi bárkitől, nem komoly, csak idevág)
Aztán én is abbahagyom a komolytalankodást, csak még egy gondolat a banánokról: Az a baj velük, hogy hetente meg kell enned 4 x 3 méter banánt, mert bebarnul. Utána meg kezdheted újra bejáratni a rendszert.revox írta: ↑2026.02.18., szer. 14:21most én lőjem le a poént, aki kiállok mások véleményszabadsága mellett? de a poén megszületett fejemben: ha leveszed a héját, esetleg pamutba tekered, lehet jobb leszakvapark írta: ↑2026.02.18., szer. 14:05Néhány hét - nap? - múlva jönnek a vélemények, a banánok saját hangjáról, származási helytől függően.MOT64 írta: ↑2026.02.18., szer. 11:37Na, és akkor ez:
https://hvg.hu/tudomany/20260216_audiof ... 0grpjjkrpd![]()
Haveromnak volt, ki is cibáltuk belőle a gyári tyúkbelet, kapott egy pár banánaljzatot és pamutos 1.5 - es egyeres-t.
( MCU )
Az egy nagyon jó kis doboz !
Viszont akkor ez sokkal több, mint 30 éves, mert az én Black Line - om is legalább 35...
Ok, lehet, ezt az ősrégi verziót nem ismertem.
egyébként kaptam 0,05mm-es (jól olvasod, 5 század mm) rézdrótot. ki fogom próbálni. Ha eljutok odáig, közzéteszem, mit hallottam. Hajlok az IC-re, de lehet csak egy digitre lesz türelmem (meg látom előre,ahogy majd szakadozik a béna kezemben, a végén csak egy jumper lesz a NAD3020 elő-végfoka közé
"hogy nem képesek érzékelni azokat a torzításokat, amelyeket a változó közeg okoz"
ez hiba, de nem tudom, készség vagy képesség. A készség fejleszthető, a képesség nem.
vessetek meg, én sose próbáltam ki ezeket a hirtelenjött drótokat. se CAT-ot,se MIG-et, semmit. Néhol hallottam szólni, az elég is volt, de elég hamar beláttam,hogy nem fogok jobbat csinálni, mint a gyártók. eleinte vdHull olcsó,aztán véletlen került hozzám beszámításba (kupeckedtem sokat régen, suli meletti ösztöndíjkiegéászítés) egy szett AN-D, aztán mem votl abban semmi csillivilli, de jó volt hallgatni. Sokan mem tudják,de az internetes hififórumok hajnalán (index), én voltam az egyik legnagyobb elleNOTEista. Sok rosszat hallottam a Merlinről, ami egyből unszimpatikussá tette őket. Aztán ez a kis drót meg jól pofánvert.
mostanában keresgetek olcsó drótokat, játszok velük, de főleg azért, hogy tudjak ajánlani embereknek,ha megkérdezik, mit vegyenek gombokért. Nemrég én is próbáltam az AVantgarde rendszert bedrótozni olcsón, miután kiszedtem belőle a Kondo ezüstöket. Egy darabig ment is, de aztán baxta az agyam és a végén réz Kondokkal teleraktam, néhol ezüst, így most békében vagyok azzal is. de ez pl nem rossz vétel, egy darabog ezzel ment. a szubok tápja még most is ilyenből van (kölcsön vannak adva a Kondo réztápok, de nem is érzem,hogy hiányozna):
https://www.ebay.com/itm/175322871212
egyébként a videó nem merítette ki a lehetőségeket,mert főleg DIY kábelekkel apellált, de arra jó,hogy meglássuk, mindig a rendszerbe legkevésbé torzat kell választani.
20-25 éve hozzám is került egy Mogami hangfalkébel. lövésems e volt,mi az,de nem volt rossz. Supertweeterhez használtam,ott jobbnak bizonyult,mint a Townshend saját drótja. de ezt próbálni kell.pjm írta: ↑2026.02.18., szer. 09:23revox írta: ↑2026.02.17., kedd 13:36belementem a játékba. elkezdte tolni a zenét és bárki kipróbálhatja, melyik tetszik neki legjobban. ha játszani akarsz, ne olvasd tovább, de beteszem OFF-ba, ne nyisd meg. Amint ment egy kört(minden kábel megszólalt legalább egyszer), még nem tudom, mi-micsoda,pjm írta: ↑2026.02.17., kedd 08:29https://www.youtube.com/watch?v=M76A6pETdww
Ezt most itt hagyom, mindenki azt tesz vele amit akar. Ez azért jó, mert a kábelszkeptikusok azt mondhatják, na látod, ő is megmondta, nincs szignfikáns különbség, a kábelesek azt, hogy látod, még mérhető is volt.![]()
várom, mire voksoltam :)
A vicc az, hogy én is az elsőre voksoltam, és az a Mogami. Nem véletlenül tartom én itthon. Egy kellemes kis kábel belépő szinten.
Nekem is megvannak még a régi sz&r kábeleim, most éppen az erkélyen vannak természetes akadályt képezni a sok szemtelen galambnak aki berepülne oda. (De persze van "hivatalos" galambriasztó tüske is, azt "kiegészítendő" alkalmazom a régi hangfalkábeleket.)
Nem kellett volna kidobni. Jó az még futóbabot kötözni a karóhoz.
Nekem az első komolyabb hangfalam valamikor a 80-as évek elején egy Kef Cantor volt (a legendás B200-as mélyközéppel és T27-es magassal) abból pl. "kijött" a drót. Gyárilag bele volt gyógyítva a hangfalkábel ...Rock60 írta: ↑2026.02.17., kedd 16:29Már a megjelölt korszak előtt volt valami benga nagy Videoton dobozom - nem rémlik már a típusa - aztán a "kék" Orion HS500 - as, Videoton Cleopátrával hajtva.Snipi írta: ↑2026.02.17., kedd 13:50
Erről a kábeldologról mindig szegény "őshifis" apám szokott az eszembe jutni. Neki volt a szava járása, kb. ez : "ha a 70-es évek végén, 80-as évek elején valaki azt mondja, hogy a kábeleknek hatása van a hangra, hát az illetőhöz rövid úton elme -és gyógy orvost hívtunk volna ... pedig de!"
Az azokhoz " ajánlott " hangszórókábeleket rögtön kukáztam, 1.5 - es és 2.5 - es tömör rezet használtam megpucolva, pamutcipőzőbe húzva.
A 80 - as évek elején jött a Pioneer HPM 60, ami már egy jóval szofisztikáltabb hang, ott már kísérleteztünk minden dróttal, ami csak számításba jöhetett...![]()
Vegyél Canaret. Tegnapi állás szerint.istvan01 írta: ↑2026.02.18., szer. 09:38Tegyük még hozzá a kibontott SATA kábelt, aztán CAT5 AWG24-es ereket is.
Ez utóbbit én is építettem, történetesen CAT5-öt DC tápkábelnek. Éppen tegnap dobtam ki, vagyis cseréletem (már megint és ismét) Neotech UP-OCC teflonos hook-up drótokkal. Nem kicsi volt a meglepi.
Jó látni téged, épp a múlt héten jutottál eszembe.
Az az igazság, hogy magamról is azt érzem néha, hogy körbe körbe járok. Ha változik valami, akkor azzal nemegyszer a kábel is változik, az előzőt ugye ahhoz választottad, ami addig volt.
A dolog szépsége, hogy az álaluk javasotak megvoltak, a Mogami azóta is itt van, tudom milyen, tudom, szerethető, de ha a többi színez ez meg a valót mutatja, akkor én nem a valót hallgatom most olyan szívesen. Ez van, botfülű vagyok, de elégedett.
Ez utóbbit én is építettem CAT5 ereket sodorva kb 1,2mm2-re, CAT5-öt DC tápkábelnek. Éppen tegnap dobtam ki, vagyis cseréletem (már megint és ismét) Neotech UP-OCC teflonos hook-up drótokkal. Nem kicsi volt a meglepi.
A hozzászólást 1 alkalommal szerkesztették, utoljára istvan01 2026.02.18., szer. 09:39-kor.
"a Hificityn"
Régi szép idők, mikor a "MIG" kábel dívott. Aztán tűzálló.
Nem kell minden hóbortnak bedőlni.
