Pro Cinema az otthonunkban
Re: Pro Cinema az otthonunkban
További képek:
- A6AD9D95-AD4B-4FD1-B2DC-14B5331F5D2E.jpeg (119.34 KiB) Megtekintve 2568 alkalommal
- F801C581-0248-4E90-A8AF-B4C41C792A57.jpeg (79.54 KiB) Megtekintve 2568 alkalommal
- C5202FB9-8569-4FE8-BCE4-80F8825CB39D.jpeg (78.36 KiB) Megtekintve 2568 alkalommal
- A0A7124D-CE16-46EE-846E-9EC5BD3D0CA0.jpeg (129.07 KiB) Megtekintve 2568 alkalommal
- E92A0CA2-2965-489B-99D7-41A6D0D2A45A.jpeg (139.12 KiB) Megtekintve 2568 alkalommal
- 1C71CCFF-D673-4C3B-BFA9-9C8F95A151B4.jpeg (83.63 KiB) Megtekintve 2568 alkalommal
- 49BF9FCD-98E6-4B02-9AB1-791D7B7E40DC.jpeg (113.57 KiB) Megtekintve 2568 alkalommal
- 98D027C0-942E-411B-923E-FC909B968D64.jpeg (105.71 KiB) Megtekintve 2568 alkalommal
- 914CC3D8-79C3-4846-8C11-73459602C607.jpeg (210.25 KiB) Megtekintve 2568 alkalommal
- 28694381-B858-4D0C-87AC-5200CBB8F588.jpeg (194.18 KiB) Megtekintve 2568 alkalommal
DIY szoba:
*JVC NX7
* DIY 158” 2.35 with center stage XD
*JBL synthesis SDP 55
*(5) JBL DSi 2.0 SA4-D Amplifiers utilizing Dante outputs from processor.
* (3)HTM-12 for LCR These are the update version with hyper lite woofer.
*(6) HT-10 for front wide and surround.
*(4) Volt 8 ported in ceiling.
Utilizing 3 independent subwoofer channels from processor.
*(2) SQL 15 subwoofers behind screen.
*(2) SQL 12 subwoofers in end tables.
* HST 18 in rear wall.
*JVC NX7
- 35B8832E-D970-404C-A6A6-B77F755BCF01.jpeg (84.84 KiB) Megtekintve 2568 alkalommal
- D6282344-4870-441A-B418-E048E9AA8C3D.jpeg (53.7 KiB) Megtekintve 2568 alkalommal
- 6D626DED-4093-4A5F-B819-4F7126DFE28D.jpeg (111.53 KiB) Megtekintve 2568 alkalommal
- 036829A4-A7DB-401A-AB14-AF0DB231B691.jpeg (124.56 KiB) Megtekintve 2568 alkalommal
- D5B7EEFE-2E79-4CCD-AC14-8D55B1B0514B.jpeg (145.56 KiB) Megtekintve 2568 alkalommal
- 58ACE75D-3673-497B-94EB-54858DA01457.jpeg (127.55 KiB) Megtekintve 2568 alkalommal
- 6E7AADD3-D67C-43A3-AD13-BCE1A15787ED.jpeg (409.87 KiB) Megtekintve 2568 alkalommal
Nyílván sok dolgon el tud bukni egy hangfal azon kívül, hogy hány utas, vannak gyengébben szóló 3 utasok és ugyanilyen 2 utasok is meg fordítva. Biztos jó okuk volt, hogy a 3 utat választották, nyilván ez nem azt jelenti, hogy vegyünk/építsünk egyből ilyet, a többi meg mehet a levesbe. Szinte biztos vagyok benne, hogy az alkalmazott hangszórókat pont az adott célra fejlesztették, tehát valszeg nem volna szerencsés belőlük 2 utast csinálni mondjuk a közép kihagyásával.
Egy 2 utasnak is megvannak az előnyei egy 3 utassal szemben, én csak leírtam pár dolgot, hogy miért lehet jó egy 3 utas.
Szerintem örülni kell neki, hogy ilyen is van, ahogy thxfan is írta.
A legtöbb gyártónál 15 inch-nél kezdődik a méret. Ha megnézed a KCS-t, a legkisebb screen sugárzó az S1200. 30centi mélyközép, 2 út. Felette már S1500 15inch mélyközéppel, de még mindig két út. S1800 2000 még mindig két út és még mindig 15 inch. Felette még mindig két út és még mindig 15 inch, de két mélyközéppel egy helyett illetve egyre nagyobb tölcsérek. Csak a legnagyobb modelleknél van 3 út. Ugyanez JBL-re is igaz. Standard méret a 15 inch, pl. 36 sorozat ott még a legkisebb 2 utas 3677 is 15 inch mélyközép, és ott is a nagyobb modelleknél dupla mélyközép és 2 út. 47-es sorozat ugyanez. pl. 4722. Ha megnézed az új C sorozatot, a legkisebb modell a C211 szintén 15 inch. Mag cinemánál van 10 és 12 inch mélyközepes 2 útban, de ugyanúgy ott is, a 15 inch mélyközepes is megmaradt 2 utasnak.
Szóval én azt látom, hogy szinte standard méret a 15 inch. Ez alá nagyon ritkán mennek, ettől nagyobbat meg soha nem használnak, csak subwoofereknél. Valamint standard a 2 út. 3 utasra csak a legnagyobb modelleket szokták készíteni, amiket kifejezetten a legnagyobb méretű mozikba szoktak ajánlani.
Persze elméletben igazad lehet, meg thxfannak is. Ha két részre osztjuk a frekvenciasávot akkor valószínűleg a top oktáv szebben szólhat, mert finomabb magasat lehet használni. Az más kérdés, hogy nem feltétlen szoktak. A középtartomány esetén a franc tudja. Kónuszos hangszóró vs. nagyméretű tölcséres magas alacsonyan váltva. Szerintem mindkettő lehet über jó. Ahogy pl. hifis hangfalaknál is vannak dómközepek, meg hagyományos kónuszos közepek. Mindkettőből van jó és rossz, mindkettőnek meg van a maga rajongótábora ahol egyik tábor egyik megoldásra, másik meg a másikra esküszik.
- -KP-
- Értékelés: 1719
Hát nem tudom.
- thxfan
- Értékelés: 1205
Hihetetlen, hogy különösen ebben, de szinte az összes topicban nem lehet már értelmesen beszélni semmiről, az offba átkerült betyárkodás meg...
Középtartománynál várnék egy kis pluszt. Nekem egyszerűen csak tetszik, bár egy vászon mögött úgysem látnám.
10.1 Auro3D
Ja azt kifelejtettem, hogy a dedikált középhangszórónak hála izmosabb mélyet és finomabb magasdrivert lehet használni, ezek pedig jót tesznek a sávszéleknek.
Bár nem engem kérdeztél, de a 3 út előnyeinek lehet nevezni mondjuk a jobb középtartománybeli érthetőséget es neutrálisabb megszólalást, főleg az alacsonyabb intermodulációs torzításnak köszönhetően. Plusz mivel ezek a JBL-ek tölcséres közepűek így még egy csökkent helyiséginterakció is megjelenik mint előnyös dolog.
“Végre 3 utas pro cinema hangfal ilyen "kisebb" méretben, ez sem elhanyagolható.”
Mi a gyakorlati haszna, hogy 3 utas? Mi a Te meglátásod, véleményed?
- Farkinca71
- Csatlakozott: 2016.07.27., szer. 23:15
- Értékelés: 274
Itt lattam a forumon ezt a valasz, ide illikupetat2 írta: ↑2020.07.09., csüt. 19:4226m hosszú és 12m széles moziba ajánlott a jbl.
Most őszintén , ezeket tényleg be kell gyömöszkölni egy , mondjuk 4x5 ös szobába? Tök jó ez a pro vonal( tényleg ezt gondolom) , de biztosítani kéne neki a megfelelő szobaméretet.
Olvasgatom amiket írtok, de kizártnak tartom, hogy bármilyen pici szobába jók lehetnek ezek....
Anthem AVM60 7.2.4
DP dVision 35 WQXGA
146” Screenline, Microperforated
Speakers: K.C.S.
LCR: 3*S-2000(C-115-PLF) Crown CDi 4/300
Surround: 6*SR-12-N, Dsi1000, IMG Stageline 400D
Atmos: 4*SR-12-N, 2*IMG Stageline 400D
Sub:2*C-218-A, 2*Marty Cube, HoverBoss-Behringer NX3000D,Crown Xls1002,1502
DP dVision 35 WQXGA
Speakers: K.C.S.
- thxfan
- Értékelés: 1205
10.1 Auro3D
- thxfan
- Értékelés: 1205
Nekem 1 pro subom van csak, az simán jó hangot tud a nagysága ellenére a 22 m2-es mozimban. Gondolom itt is túl lehet tolni a dolgokat, mint mindenben...upetat2 írta: ↑2020.07.09., csüt. 19:42
Ez a legutóbb linkelt LCR hangfal 128 cm magas és 56 cm széles. Egy izmosabb "átlagos" front hangfaltól szinte alig magasabb, viszont szélesebb, itt nem divat a sok kisebb hangszóró alkalmazása, hogy nappalikompatibilis kinézete legyen. Végre 3 utas pro cinema hangfal ilyen "kisebb" méretben, ez sem elhanyagolható.
A hozzászólást 1 alkalommal szerkesztették, utoljára thxfan 2020.07.11., szomb. 12:49-kor.
10.1 Auro3D
Hát írhattad volna, hogy igen be lehet integrálni és tök jó , vagy azt , hogy nem .... ha megválaszolom a kérdésed , akkor ez ki fog derülni?
Azt gondolom, ha végigolvastad volna a topikot, ami lassan 1 éves lesz, akkor nem hitetlenkednél, még ma is
- upetat2
- Csatlakozott: 2007.01.24., szer. 16:50
- Értékelés: 35
Hallottál már akár csak egyetlenegyet is szólni???
Projektor: 3chip DLP,Digital Projection Highlite 660 /
Lejátszó: Oppo93eu / Védelem,szűrő: Isotek Mirra,Isotek Solus,
Hdmi: Furutech,AudioQuest / Tápkábelek: Furutech,Audioquest
- -KP-
- Értékelés: 1719
Tuti jó cucc lesz, de szerintem nem lesz elérhető árú. Az ilyen 3 utas darabok mind 2,5-3 ezer eurós darabáron mennek többnyire.thxfan írta: ↑2020.07.09., csüt. 17:55JBL-től jön egy egész jónak tűnő kisebb mozikba való szett, élhető méretű 3 utas LCR, egész pofás hátterek, azt írják olcsó és jó lesz:
https://jblpro.com/en/product_families/ ... ion-series
https://musicmedia.hu/jbl-cinema-expans ... s-20200517
- -KP-
- Értékelés: 1719
Hallottál már akár csak egyetlenegyet is szólni???upetat2 írta: ↑2020.07.09., csüt. 19:4226m hosszú és 12m széles moziba ajánlott a jbl.
- upetat2
- Értékelés: 35
- thxfan
- Értékelés: 1205
10.1 Auro3D
- Farkinca71
- Értékelés: 274
Nalam is detto ugyan ez a helyzet. Az en rendszerenben , az en fulemnek, kell a surroundok es a magassagi hsz-k hangerejenek novelese a LCR-ekhez viszonyitva.
A hozzászólást 1 alkalommal szerkesztették, utoljára Aszpirin 2020.06.20., szomb. 11:03-kor.
Ok: szerkesztési célű véletlen saját idezés kijavítása
Anthem AVM60 7.2.4
DP dVision 35 WQXGA
Speakers: K.C.S.
DP dVision 35 WQXGA
Speakers: K.C.S.
- Quetz
- Értékelés: 741
Arról nem beszélve, hogy hány esetben dokumentálták a rajongók, hogy zuhant a mix minősége DVD -> Bluray > UHD Bluray Atmos remixelés során. A lapos tv-k és soundbarok korában már nem mindig cél a hangminőség.
