Interneten talált képek
- giotto14
- Csatlakozott: 2015.08.27., csüt. 07:28
- Értékelés: 465
A lányok mögött valami világít :-) Ocean's Eight
"Ma az emberek tudják mindennek az árát, de nem tudják semminek az értékét." /Oscar Wilde - Dorian Gray arcképe/
22 hours ago, Vinkler said:
Végfokok.
Sim Audio's Moon 888 monoblocks.
Specifications:
Output Power at 8Ω: 888 Watts (1.2HP)
Output Power at 4Ω: 1776 Watts (2.4HP)
Input Sensitivity: 2.4V RMS
ebből három elvinné a dobozaidat, bár nem tudom elég-e ez a magasak alá
Végfokok.
Specifications:
4 hours ago, asebestyen said:
Nem, ebbe már gyárilag bele van építve, azért is kellett ekkora doboz neki.
Beleférne vagy 20 liter turmalin
10 minutes ago, supravox said:
Khmm..
De VF nélkül biztos ez is gatya..
- asebestyen
- Értékelés: 8266
Khmm..
Végfokok.
Every decade or two an idea borne from beyond the confines of our economic reality comes into being. A team of dedicated and passionate professionals assemble with one singular goal in mind: to design and bring to the world a new superlative level of musical reproduction. It is a forward leap redefining what is possible.
The cumulation of technical expertise, combined with passion and a relentless pursuit for perfection has led to the creation of the MOON 888. This isn’t just another monoblock amplifier. It’s a statement. It is a concept taken to the extreme in every detail. The impressive power output is actually very modestly rated at a “mere” 1.2hp (888 watts). This is backed by a gargantuan power supply that coupled with an 8kW capacity output section on enormous cast-aluminum heatsinks can drive any load with complete effortlessness.
The ineffable clarity unleashes musical detail that was, up until now, considered unattainable. The MOON 888 can “track” the musical signal so accurately that it simply does not impart any character of its own. For the first time the awesome dynamics of real live music are possible in the playback chain.
The 888 is State-of-the-Art taken to the extreme.
Specifications:
Input Impedance: 24KΩ
Gain: 31dB
Signal-to-noise Ratio: 120dB @ full power
Frequency response (full range): 10Hz - 200kHz +0/-3.0dB
THD (20Hz - 20kHz @ full power): 0.04%
Intermodulation distortion: 0.006%
Shipping weight: 300 lbs / 136 kgs
Dimensions (width x height x depth): 22 x 14 x 27 in.
55.9 x 35.6 x 68.6 cm.
Khmm..
Végfokok.
Specifications:
Gain: 31dB
- Vinkler
- Adminisztrátor
- Értékelés: 10134
Végfokok.
Specifications:
Gain: 31dB
- fodesz
- Értékelés: 5164
Igényeseknek...
Nincs olyan amihez ne lenne jó a vinyl
A steampunk stílus kedvelőinek...
Több, mint 20 mérföldre elhallatszik a hangja. Klassz lehet a környéken lakni...
https://www.sumburghhead.com/foghorn
Bár, ahogy a Google Maps-on nézem, ez kb. 25 embert érinthet.
Ott biztosan egy tölcséres hangsugárzót sem lehetne eladni,még a fagyit is kehelyben kérik.
- Rotox
- Értékelés: 1494
- dualcs5000
- Csatlakozott: 2007.01.03., szer. 17:38
- Értékelés: 378
Weiss
- dualcs5000
- Értékelés: 378
valóban az!
és ha sikerül elvonatkoztatni,hogy hol és mikor készült...
Több adpektusbólmis jó ez a kép...
Ha valakit érdekel, innen van:
https://www.independent.co.uk/news/worl ... 30691.html
- Vinkler
- Adminisztrátor
- Értékelés: 10134
valóban az!
- GTomi
- Értékelés: 744
Ez de jó kép.
valóban az!
Jó kép tényleg.
Ezt a szobát mérje be valamelyik akusztikai szakember
Ezt messziről mérték be....
- fodesz
- Értékelés: 5164
Jó kép tényleg.
Ez de jó kép.
- Vinkler
- Adminisztrátor
- Értékelés: 10134
Ez de jó kép.
Elfújta a szél a dalom :-)
CD : Ayon CD1
Amp : Pathos Classic One + Soundcare
Speak : Sonus Faber Olympica I
Cable : Audio Note AN-V, HarmonicTech Pro 11 plus
Power : PS Audio PPP, HarmonicTech Fantasy AC 10, Lessloss DFPC Original & Signature
Akusztikailag kezelt zeneszoba
hájgend
by SAL
- giotto14
- Értékelés: 465
hájgend
- gyt
- Csatlakozott: 2016.02.05., pén. 13:15
- Értékelés: 237
És van egy magyar cég, aki vinyl lemezekből készít szemüveg kereteket, nem is akármilyeneket! Ezekben van annyi innováció, hogy értelmes újrahasznosítás.
Viszont az LP-ből készült óráktól engem is kiráz a hideg... de a tál is zavarna
... van órám is, de az nem LP-ből készült, csak úgy néz ki. Érdekes, az nem zavar.
Heed, Soulines, Power-R
Sok olyan zenei felvétel létezik vinyl lemezen, amelyekből SOKKAL hasznosabb tárgyat készíteni (mint ahogy említettétek: például óra, névjegykártya), mint meghallgatni... Sok ilyen példám akad a nejem 30-40 éves gyerekkori LP-i között . Az ilyenek borítóinak látványa meg felér egy szívsokkolóval!
