Fish mozinappalija
- Red75
- Értékelés: 830
Fish mozinappalija
a háttér hangsugárzóim.. iszonyat jó teret tolnak , nem hittem volna de marha jó cucc..
Emlékszem, a középső kapcsolóval lehet állítani, hogy dipol, vagy bipol, esetleg egyik oldalon szóljon csak.
Nagyon 5letes.
Fish mozinappalija
egy barátom hozta el hozzám egy kis tesztre a kis Focal profile hangfalait.. jó kis nap volt és az is bebizonyosodott ,hogy lehet jó minőségű polc sugárzókkal is jó mozit csinálni..
Fish mozinappalija
S12
A truly multi-faceted performer, the Concerta S12 surround loudspeaker can be configured for different dispersion characteristics according to the type of surround effect desired as well as for different placements within the listening room. Featuring a pair of woofers with Organic Ceramic Composite (OCC) cones, as well as a pair of OCC dome tweeters with neodymium magnets along with our proprietary Constant Acoustic Impedance technology, the S12 offers unparalleled surround sound versatility.
Three dispersion modes are user-selectable via the front panel switch. Choose Dipole mode for side-of-listening area placement, where the two-driver pair sets operate in reverse phase mode, which minimizes localization while providing broad surround sound dispersion – ideal for movie surround soundtracks. Bipole mode provides the best combination of dispersion and improved localization for pinpoint surround sound imaging with SACD, DVD-Audio, DTS® and Dolby Digital® multichannel music surround sources. A third Monopole mode allows the deactivation of one of the two driver sets, when spot-on imaging is desired, such as for discrete multichannel pop music.
For 7.1 systems such as THX Ultra2® Dolby Digital EX® and DTS ES®, the S12 also features dual separated crossovers and two pairs of speaker input terminals. By removing the shorting straps on the binding post pairs, one S12 can function as two distinct surround loudspeakers in a single enclosure. This unique capability allows the use of one S12 to function either as both left and right rear surrounds, or as both a side and rear surround speaker. The Concerta S12 can therefore provide a unique solution for 7.1-channel systems in tight spaces.
Fish mozinappalija
ha egyszer nékem sok pénzem lesz.... Performa c52
Performa f208
Fish mozinappalija
De akkor nem lesz Ipad-ed az Arcam-hoz, mint Fish-nek!
22-es csapdája
Fish mozinappalija
RENDBEN
őőőő én azt gondoltam,hogy csak az ipad-t adod..
Fish mozinappalija
RENDBEN
vagy cserélhetünk is
RENDBEN
Megy az Ipad+Sheri+Marantz és jön az Arcam Szuper jó hír mára vagy inkább az egész évre
Fish mozinappalija
RENDBEN
Fish mozinappalija
Fish mozinappalija
Nekem is tetszett, ezért nem szégyen. Nem is tudtam, hogy lesz folytatása.
óhh lesz még több is ha jól emlékszem 5 könyv is van..szóval lesz folytatás bőven
http://www.imdb.com/title/tt4046784/
- Red75
- Értékelés: 830
Fish mozinappalija
Vasárnap ezt néztük meg, szégyen vagy nem szégyen nekem tetszett, kicsit sötét hangulatú volt de várom a folytatást..
http://www.imdb.com/title/tt1790864/
Fish mozinappalija
Fish mozinappalija
Basszus, van Ipad-em, akkor már csak egy Arcam 450 kellene olcsón
Fish mozinappalija
Revel hez az dukál tudok valaki aki ismer valakit aki esetleg szerezhet olcsóbban... csak neked csak most..
Fish mozinappalija
Fish mozinappalija
Igényes és komoly technika a mostani és az azelőttiek is, grat. hozzá, a szoba is nagyon jól néz ki, igazi mozis hangulatú.
Az étkező leválasztása a nappalitól nagyon jó lépés volt, valószínűleg az akusztikán is javított.
hello köszi!
Akusztika nálam sajnos elég kényes téma, ha lesz rá idő+keret majd azon még elég sokat kell dolgozni ,hogy elfogadható legyen, a szőnyeg és a vastag sötétítő sokat hozott ,de elférne pár akusztikai panel az biztos..
- thxfan
- Értékelés: 1199
Fish mozinappalija
10.1 Auro3D
Fish mozinappalija
Ezért írtam egyszer, amikor megvetted a DD18-at, hogy az már lehet egy kicsit túlzás.
Arról azonban én is szívesen olvasnék pár sort, hogy milyen volt a két ULTRA Velodyne után.
erre akkor külön. túlzás is meg nem is.. nagyon tetszett ,cserébe a 2 ultra van olyan jó mint egy dd18, és persze jó környezetben meg nem biztos.. nálam ,vagyis én nem tudtam igazán kihasználni az 1 nagyot ,ezért is ment ,persze fájó szívvel mert egy ilyent birtokolni nem rossz dolog, és a tudása és a mérnöki bravúr amit a servos vezérléssel megcsináltak az valami hihetetlen, az a marha nagy membrán olyan gyors tud lenni mint egy ultrába 12-es, nem semmi,no meg persze a profi hitech mikrofonos bemérő rendszer+ sw hmm a világ legjobb ládájának tartom a DD-ket,szóval sztem innen felfele már nem igen van de értelme sincs már az is biztos cserébe a "kis" ultra nagyon jó cucc,a 450-el most annyira jól belőttem ,hogy 1-el is zseniális..azt hiszem nekem ennyi pont és bőven elég ,nem fixa ideálom szétverni a házat a ládákkal egy egy jelenetnél, de ha kell zúz ez most is persze.. szóval bőségesen elégedett vagyok a kisebb ultra tudásával kevesebbért.. de a dd18 nagyon jól mutatott a sarokban azért
Fish mozinappalija
Számomra a mostani rendszered a tökéletesség mintapéldája.
Egy mozis-nappaliba a "pont és bőven elég mindenre" rendszer.
A rendszer elemei azonos kategóriát képviselnek, nem lóg ki semmi a sorból.
ezt köszönöm szépen, jól esik, próbáltam mindig is a realitás talaján maradni, mozogni..a túl kitűnő ,kilógó egység az valóban nem túl jó dolog mert fel kell fejlődni hozzá és az pénzben nem tréfa már!
Fish mozinappalija
Fish mozinappalija
Ráadásul ez működhetne majdnem folyamatosan!
Gondolom a Sim2 LED-ben is nagyon alkotott!
nem is az első led-s masinájuk ott az m széria is és ez a "belépő" modell a sim2 ledes világába( sztem ez már kezd az elérhető kategóriába esni, de használtan, ha lesz ilyen egyszer, biztosan jóval olcsóbban hozzáférhető lesz, a többi drágább jószág és akkor még hol vannak a 3chip-es lumisok
Fish mozinappalija
Amit nagyon szívesen kipróbálnék: ( egyszer valami ilyesmi csere lesz ha lesz valamikor )
http://www.av-online.hu/projektor/sim2- ... teszt_1413
http://www.hazimozistudio.hu/webaruhaz/ ... projektor/
Fish mozinappalija
Amit még ki akarok próbálni az az arcam 450-es ipad-os vezérlése.. gyári progit írtak hozzá ami ingyenesen letölthető.. azt hiszem be kell szerezzek valami ipad-t olcsón.
https://itunes.apple.com/gb/app/arcamre ... 72828?mt=8
Fish mozinappalija
Fish mozinappalija
Jó cuccok fordultak meg nálad.
A mostani rendszer is nagyon jó lehet
A DD18 gondolom nem egy gyenge darab lehetett
Köszi! Nem volt rossz ez tény
