Harbeth hangsugárzók
Zene:
Harbeth M30.2 40th - QUAD QMP - QUAD Artera Play - Cambridge Audio 851N - Puritan PSM 1512 - MZ/X LPS - Cisco Meraki - Quadraspire - Final Lab Daruma
Mozi:
Mozi:
Igazán a 40.1 érdekelne.
Szívesen meghallgatnám majd, ha megjön hozzátok.
Üdv
Azért az avalon-ról se feletkezz meg, amiről beszéltünk!
/emoticons/default_smile.png" alt=":)" data-emoticon="" srcset="/emoticons/smile@2x.png 2x" width="20" height="20" />
Üdv
Még nem.
Baromi lassúak.
A 30.1-es csere is folyamatban van.(nem a speciális kivitelt küldték)
Azt lehet el fogom adni,ha megjön a 40.1-es.
Ha érdekel,akkor ki sem bontom.
- ajkamici
- Csatlakozott: 2010.04.07., szer. 16:01
- Értékelés: 882
Üdv
Még nem.
Baromi lassúak.
DCS Debussy / Leben CS600 / Pro-Ject RS2T / Harbeth M40.2 - Entreq Olympus - Shunyata Research és Power-R kábelek
Megjott a 40 es Harbeth ?
Udv
Még nem.
Baromi lassúak.
Webáruház:
http://www.avxcafe.hu/
Udv
Talán a jövőhéten.
- ajkamici
- Értékelés: 882
Udv
Talán a jövőhéten.
Harbeth M30.1
"I traveled down to Fidelis, the U.S. distributor, intending to audition and probably purchase the C7ES3. I spent two hours listening to CDs I had brought (Joni Mitchell, John Coltrane, Dizzy Gillespie, Cannonball Adderly/Miles Davis, and Alison Krauss). So jazz, pop, and acoustic; no classical, no rock. The C7s are wonderful speakers and I was very happy with them. I then asked to substitute the M30.1s, not because I thought I might prefer them by any significant margin but simply out of curiosity since I was aware that there is a buzz about them in the U.S. audiophile press. To me, the difference was obvious, unmistakable, and solidly in the M30.1's favor. If the smaller speakers gave up anything in the bass, I couldn't detect it. What the M30.1s had over the C7s was, to my ears, significantly truer reproduction of timbre, which led to a significantly greater emotional involvement with the music.
This was not a case of the M30.1s playing a little louder and my perceiving it as better, something I was on guard against. I played both sets of speakers at various volumes and listened and re-listened to the same passages many times. The timbre of trumpet, piano, saxophone, and vocals was, to me, significantly truer through the M30.1s.
Earlier in this thread, Alan Shaw agreed with a poster that the differences between the M30.1 and the C7 are small. He added, "If you want to believe that I have worked some special magic into the M30.1 that I couldn't into the C7ES3, great! Perhaps I have." At least he admits the possibility. Having heard both, I have the utmost respect and admiration for Mr. Shaw's accomplishments and I hesitate to say the difference is great when he says it is small. Nonetheless, this is my perception.
I am a musician. Possibly I have a peculiar sensitivity to timbre. It is not surprising to me that the M30.1, with its better tweeter, is truer in this regard. Timbre is determined by a note's harmonics, which must be presented in the proper relationship to one another (and to the fundamental) in order to be perceived as correct. The harmonics of some instruments go quite high.
I am certainly not saying that the M30.1 is a better speaker for everyone. The lesson I draw from this is that expectations are no substitute for experience and nobody else's experience is a substitute for your own. I am so glad I auditioned both.
The difference in price between the C7ES3 and the M30.1 is not trivial, certainly not to me. I ordered the M30.1s."
Zene:
Mozi:
Mozi:
Zene:
Mozi:
Mozi:
Azóta megcseréltem és Nagy Lacival (L Auditor ) is megfüleltük közösen.
Lacinak is nagyon tetszett.
Valóban mégjobb lett.
Még annyi az infó,hogy a gyár elcseszte a rendelésem.
Kicserélik egy olyanra,mint a tied,addig meg ezt hallgathatom.
Még jó hogy a 40.1-ből nincs 35th AE.Így legalább nem keverednek bele
Akkor a jövő héten 40.1?Várjuk a beszámolót.
Zene:
Mozi:
Mozi:
Mikor jön a negyvenes?
Béla!
A képek alapján ezt rosszul kötöttétek össze!
Vagy valaki levette az elejét és rosszul rakta vissza?
Cseréld ki a két oldalt.
Left+Right(a Harbeth felirat kívül kell,hogy legyen)
Ha eddig is tetszett akkor ezután még jobban fog.
Webáruház:
Zene:
Mozi:
Mozi:
Zene:
Mozi:
Mozi:
Kíváncsi leszek mennyit hoz a hangon a fém állvány, látni elég sok spéci fa állványt is a Harbethek alatt.
Köszönöm az invitálást, megpróbálok eljutni hozzátok! A 40.1 lőtávon kívül van, viszont levinném a Naim-et, ha nem gond, megfülelni, hogy tényleg érdemes-e váltanom 30.1-re.
Ok,hozd nyugodtan.
A 40.1 az összehasonlítás miatt érdekes.
közebn nekem is megjöttek a fém állványok.
Ezzel is biztosan jobb lesz a hangja.
Trane-től vettem.Ő is a Harbethet erre pakolta annó.
Webáruház:
Kíváncsi lennék,hogy a 3-as miben külömbözik ettől.
A 30.1-es nekem is sokkal jobban tetszik,de az ára sem egyforma.
A 30.1 és a 7C3-as gyári ára közütt viszont nincs nagy árkülönbség.
Ha megjön a 40.1-es,akkor eljössz megfülelni?
Régi modell és a színe sem jó.
Webáruház:
Régi modell és a színe sem jó sajna.
Ezért kell 2-est venni jó áron.
Ez a C7ES-3 kicsit erősen van árazva http://www.ebay.de/i...=item3cce5d0970
Webáruház:
- suminator968
- Értékelés: 1082
Viszont legalább nagyon szép!
Mennyi lehet a tiszta haszon? 2 millió?
Jó lenne tudnom,hogy tényleg mennyi doboz megy el,mert ha 2000 fölött,akkor az már nem rossz.
Ennek a 30.1-es kb 1000-1200- EUR lehet a gyári ára Nettó.
Ebből szerintem 300-500 EUR a haszon.
Ha az átlagot vesszük,akkor kb 2 Millió megmaradhat.
Gondolom a 40.1-en sokkal nagyobb a profit.
A váltó és a doboz árát te is meg tudod saccolni.
Kb 100000 Ft-ból kijön nagyobb tétel esetén.
A hangszórók ára sem lehet több.
A munkabér és a gyár költsége lehet kb 200000 Ft.
Összesen 4-500000 Ft,ami kb 1700 EUR.
A bolti ára 12000 EUR Áfával.
Kb 4000 EUR a gyári Nettó ár.
Webáruház:
Számoljunk:
Évente tuti,hogy elmegy 1000-1500 pár doboz,ami kb 5 Millió EUR forgalom lehet.
Nézd meg a sorozatszámokat.
A szigony-é meg az enyém között van 100 valamennyi különbség.
Ő kb 2 hónapja vette.
Komoly!
Érdekes, hogy így is szépen megy a cég hosszú évek óta. A honlapjuk is egy olyan kis egyszerű valami, nem túl sok infóval. Mi lenne ha foglalkoznának vele?
259-409=150 pár
Számoljunk:
Webáruház:
