Usher
AVX
Értékelés: 3310
Usher
Hozzászólás Szerző: AVX »
RWS-708
weight: 18kgs (including base)
dimensions (w x d x h): 33 cm x 33cm x 60~70 cm
**For all X series , BE-718, BE-718 diamond
139000 Ft/pár
AVX
Értékelés: 3310
Usher
BE-20 diamond
3-way system : Diamond DMD dome tweeter 1.25" ,
mid-low woofer 5" (0541A),
and  low-bass woofer 11"x2 (ETON 11-584)
sensitivity: 90 dB @ 1 watt / 1m
nominal impedance: 4 ohms
frequency response (-3 dB): 23 Hz ~ 40 kHz
power handling: 200 watts
crossover frequencies: 385Hz and 3.5kHz
weight: 123 kgs (including base)
dimensions (w x d x h): 36.5 cm x 89.5 cm x 140 cm
4790000 Ft/pár
AVX
Értékelés: 3310
Usher
BE-10 diamond
3-way system: Diamond DMD dome tweeter 1.25" ,
Be dome woofer 5" (0541A),
and low-bass woofer 11" (ETON 11-584)
sensitivity: 89 dB @ 1 watt / 1m
nominal impedance: 8 ohms
frequency response (-3 dB): 24 Hz ~ 40 kHz
power handling: 180 watts
crossover frequencies: 385 Hz, 3.5 kHz
weight: 92 kgs (including base)
dimensions (w x d x h): 36.5 cm x 71.5 cm x 121.5 cm
3990000 Ft/pár
AVX
Értékelés: 3310
Usher
CP-8871 diamond
mid-low woofer 7" (8948A), and  low-bass woofer 8"x2 (8955A)
power handling: 150 watts
crossover frequencies: 276 Hz and 2.72 kHz
weight: 105 kgs (including base)
dimensions (w x d x h): 31.5 cm x 85 cm x 137 cm
3290000 Ft/pár
AVX
Értékelés: 3310
Usher
CP-8571 diamond
mid-low woofer 7" (8948A), and low-bass woofer 8" (8955A)
sensitivity: 87 dB @ 1 watt / 1m
frequency response (-3 dB): 26 Hz ~ 40 kHz
crossover frequencies: 282 Hz and 2.52 kHz
weight: 87.3 kgs (including base)
dimensions (w x d x h): 31.5 cm x 76 cm x 121.5 cm
2290000 Ft/pár
AVX
Értékelés: 3310
Usher
BE-718 diamond
2-way system: Diamond DMD dome tweeter 1.25" ,
mid-bass7"(8948A)
frequency response (-3 dB): 42 Hz ~ 40 kHz
power handling: 80 watts
crossover frequencies: 2.06 kHz
weight: 17.2 kgs
dimensions (w x d x h): 25.8 cm x 42.8 cm x 38.7 cm
790000 Ft/pár
AVX
Értékelés: 3310
Usher
Dancer Mini-Two diamond
2-way system : Diamond DMD dome tweeter 1.25" ,
mid-low woofer 7"x2 (8948A),
frequency response (-3 dB): 28 Hz ~ 40 kHz
power handling: 100 watts
crossover frequencies: 2.7 kHz
weight:  41 kgs (including base)
dimensions (w x d x h): 34 cm x 48 cm x 123 cm
1490000 Ft/pár
AVX
Értékelés: 3310
Usher
Dancer Mini-One diamond
2-way system : Be dome tweeter 1.25" (9980-20BEA),
frequency response (-3 dB): 38 Hz ~ 40 kHz
power handling: 90 watts
crossover frequencies: 2.3 kHz
weight:  28.2kgs (including base)
dimensions (w x d x h):  31 cm x 36.5 cm x 105 cm
990000 Ft/pár
AVX
Értékelés: 3310
Usher
CP-777 Diamond
AVX
Értékelés: 3310
Usher
A kedvenc monitorom
CP-777 Diamond
CP-777 diamond
woofers 7"x 2 (8948A)
frequency response (-3 dB): 32 Hz ~ 40 kHz
crossover frequencies: 2.74 kHz
weight: 36.9 kgs
dimensions (w x d x h): 31.6 cm x 59 cm x 64.7 cm
1990000 Ft/pár
tukacsin
Csatlakozott: 2009.01.13., kedd 16:55
Értékelés: 33
Usher
Hozzászólás Szerző: tukacsin »
Mini monitorok...
Szépek
"A zene egyfajta mantra, amely megnyugtatja a lelket. Ugyanúgy szükségünk van rá, mint az ételre."
/Michael Jackson/
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7647
Usher
Mini monitorok...
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7647
Usher
Usher R-3.0
Usher
Usher s-520 milyen woofer található?Nagyon hasonlatos a Proac R SC1-ben találhatóhoz ?Seas T14RCY/P-H amire a clone épül még jobban.
Csak hasonlít rá....
Küldtem privit az ügyben.
Streamaudio
Csatlakozott: 2007.09.25., kedd 20:09
Értékelés: 47
Usher
Hozzászólás Szerző: Streamaudio »
MOst itt van nálunk a már kifutott X-708 is és nagyon kellemes a hangja, bár mellé rakva a BE-718-at azért lemarad, de persze az majdnem kétszer annyiba kerül....
Stream Audio Kft.
1142 Budapest Szatmár u. 54/b
www.streamaudio.hu
entrylevel
Csatlakozott: 2009.07.25., szomb. 16:20
Értékelés: 10
Usher
Hozzászólás Szerző: entrylevel »
Két csatornás sztereó rendszer.
Néha be is kapcsolom
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7647
Usher
Usher Be-718 Tiny Dancer
diy_mu
Csatlakozott: 2009.05.08., pén. 17:06
Értékelés: 14
Usher
Hozzászólás Szerző: diy_mu »
Usher D2 :lol!: potom 236 kg
# Tweeter: world famous Beryllium (TAD TD-4001)
# Woofers: 15" custom bass drivers (15HM)
# Sensitivity: 98dB @ 1W/1M
# Impedance: 4 ohms nominal
# Frequency: 28-20k (-3dB)
# Power Handling: 200 watts
# Crossover Frequency: 760Hz
# Dimensions: 28" w x 31" d x 70" h 71cm x 78cm x 176.5cm
# Weight: 600 lbs ea. (approximate) 236 kg
diy_mu
Értékelés: 14
Usher
V-604 finom
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7647
Usher
Rendelj bele az új tweeter-ből kérdés az, mennyit kellene a válton modifikálni...
Ezen már én is agyaltam.
Majd megkérdezem.
Én betársulok melléd,nekem is kell egy pár DMD tweeter...
Bekérem az árát.
Nincs valami konkrét típus?
Ez az egyetlen létezik belőle szerintem.Nekem furcsa azért,hogy váltó módosítás nélkül mindegyik típushoz megfelel.(Bár lehetséges,hogy az ezt megelőző Be tweeter is minden típusban azonos volt,így érthető lenne a módosítás nélküli upgrade lehetősége.)
Gyakorlatilag akiket idáig kérdeztem,külföldön,belföldön egyaránt,nem tud semmit sem róla...
(Állítólag a gyár sem nyilatkozik a paraméterekről.)
A legtöbbet idáig a SteamAudiós Miklós derített ki a DMD magasról.
AVX
Értékelés: 3310
Usher
Majd megkérdezem.
Bekérem az árát.
ValhallA
Tizezresek klubja
Tizezresek klubja
Értékelés: 7647
Usher
Majd megkérdezem.
AVX
Értékelés: 3310
Usher
Hagyd meg a dobozod olyannak, amilyen, ha tetszik, inkább vegyél egy másmilyent . Mondjuk Mini-One Diamond-ot.
no igen.
Félek is,ha belenyúlnánk,a kutya sem venné meg tőlem később.
Mathias
Értékelés: 274
Usher
Hozzászólás Szerző: Mathias »
Usher BE-718
Egy újabb Ushert lehet,hogy én is veszek magamnak,de nem tudom,hogy jobb lenne e,mint a CP-777.
Majd megkérdezem.
AVX
Értékelés: 3310
Usher
Usher BE-718
Majd megkérdezem.
