Matrix Cube dac+ Halide Bridge
Új irányár: 25000Ft.
Időközben a Halide Bridge elkelt, a dac új irányára 28000Ft.
Letét ellenében saját rendszerben tesztelhető.
Eladó egy Matrix Cube dac. BNC adapter jár hozzá.
Features:All the following features enable CUBE to explore every small detail in the music for you ,and provide you a tactile sensation of its sound performance ,with its ultra-high resolution and signal-to-noise ratio, to fully meet your demands for a high-quality Hi-Fi.1.Top 24Bit/192KHz D/A converting units,WM8740 of Wolfson.2.High-end T1 digital Sampling Rate Increase processing chip-SRC4382.3.ASRC(Asynchronous Sample Rate Converter) the technique of separating the internal and external clock and resampling, which effectively reduces the timing jitter generated by the former sources and transmission lines.4.A professional digital receiver chip of ultra-low jitter and a high-precision clock independent system clock.5.USB,OPTICAL,and coaxial digital signal input modes,and a coaxial output.6.Up to 24BIT/192KHz digital signal input.7.ASRC Sampling Rate can be increased to 174.6KHz/192KHz and putout through digital channel.8.Its internal headphone amp unit can easily drive any headphones of 300 ohms and below.9.Headphone amplifier can work independently when it is connected to external signal.10.A professional stereo OP-Amp,OPA2134/LM833, to provide you with the best signal playback effect.11.Its internal circuit units adopt the multi-stage stabilized voltage supply respectively.
Input :Optical :Sealed optical input ;Sampling Rate:32KHz-192KHz/24bitBNC :Standard BNC 75ohm ;Sampling Rate: 32KHz-192KHz/24bitUSB :Standard USB Connector ;Sampling Rate:44.1KHz-48KHz/16 bit
Output :Coaxial Output RCA jack Sampling Rate: 32KHz-192KHz ; Supports AC-3DTS data output Output Level : 0.5Vp-p(75ohm)Analog Interface:RCA Output Level :2.0VRMSRCA Input Impedance : 47k ΩFrequency Response : 20Hz-20KHzSNR : 109dBDynamic Range : 107dBDistortion : < 0.0005%(1KHz)Power Requirements : AC 220V 50/60Hz ; AC 110V 50/60HzPower Consumption : < 15wWeight:1.1kgOperating Temperature : 0-+40°C
Windows 10 alatt is teszteltem USB bemeneten keresztül, szépen működik, ha valaki így szeretné használni. Elsősorban dac-ként ajánlom, mert a fejhallgató erősítőjénél inbalance jelenség figyelhető meg alacsony potméter állásnál, ez a potméter 2 órás állásánál eltűnik. Összességében a produkciója nem hasonlítható egy külön fejhallgató erősítőhöz.. Egy cikk róla:
http://www.head-fi.org/t/516993/review-matrix-cube-dac
Irányár: 33000 Ft
Igény esetén van hozzá egy Halide Design Bridge USB Spdif átalakító, amellyel 24bit/96KHz jelátvitel lehetséges USB-ről nagyon jó minőségben. Windows 10 alatt is szépen működik, drivert nem igényel. Ennek irányára 33000 Ft. A dac és a Halide együtt 60000 Ft. Alku lehetséges.
